JoeOtt
Dec 26, 2017Star
R6700 Losing ability to connect at 2.4Ghz
I have an R6700 with the latest firmware (.36) on it. What has started happening since the last update is I will notice that all 2.4Ghz connections will drop off the connection list on the router. Th...
- Jan 28, 2018
Have not had a reoccurrence of the issue since the hot fix. Looks like it resolved the issue.
JamesGL
Jan 28, 2018NETGEAR Employee Retired
Hi klpeters,
Any update on the hot fix firmware?
JamesGL
Jan 30, 2018NETGEAR Employee Retired
Hi klpeters,
Thank you for confirming.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
