flute
Jun 16, 2017Aspirant
R6700 Lost Wifi after 3 years
I lost wi fi after 3 years of no problems. How can I get wi fi back? Netgear Nighthawk AC1750 Model R6700
- Jun 19, 2017
I did not get this working and bought an R6900P, which does work. Also, I was able to register the new R6900P. Thank you all.....
flute
Jun 19, 2017Aspirant
Thank you for answering. The 5 and 2.4 lights were out and I could not get anything to work. Plus I knowcked out our Mini Tivo during the adventure. I bought a new Netgear router at Costco because I had incurred extra data charges on my cell phone. I just let this problem go for too long. The costco reviews of Netgear routers are very bad, but that is all they have at our local warehouse. We are remote and captive consumers.....
flute
Now I cannot register my new router R6900 with Netgear because I already have an account under my email address. How do other people handle this problem?
- FURRYe38Jun 19, 2017Guru - Experienced User
I would check near by environment for interferences.
Check the power adapter tip for correct voltages and amps. Can be a cause of router problems if power adapter isn't working right.
Has a factory reset been performed?
Try a manual reload of FW and factory reset and set up from scratch using IE11 or FF.
Contact NG support for registration issues.
