flute
Jun 16, 2017Aspirant
R6700 Lost Wifi after 3 years
I lost wi fi after 3 years of no problems. How can I get wi fi back? Netgear Nighthawk AC1750 Model R6700
- Jun 19, 2017
I did not get this working and bought an R6900P, which does work. Also, I was able to register the new R6900P. Thank you all.....
Jun 19, 2017Guru - Experienced User
I would check near by environment for interferences.
Check the power adapter tip for correct voltages and amps. Can be a cause of router problems if power adapter isn't working right.
Has a factory reset been performed?
Try a manual reload of FW and factory reset and set up from scratch using IE11 or FF.
Contact NG support for registration issues.
flute
Jun 19, 2017Aspirant
