occicat
Apr 01, 2022Star
r6700 now missing Transmit Power Control on firmware V1.0.4.122_10.0.95
I've got four wndr6700's and had the ability in the past to adjust the signal strength of each unit based on it's location to tailor performance. Recently I've noticed a degradation in perform...
occicat
Apr 02, 2022Star
I have a few r6700's. I tried to edit the model in the first post but don't have the necessary permissions to do so. I have a few wndr4300's which is also being used as an AP and most likely transposed the models during the posting.
I've, and others in the postings above have scoured the entire admin control panel and it's simply not there. Case in point, the attached photo I provided shows that the feature has been commented out in the markup as well.
Apr 02, 2022Guru - Experienced User
Something to contact NG support about then. Thats something thats is beyond forum help.
https://my.netgear.com/support/contact.aspx
Good Luck.
