aesopic
Nov 10, 2022Follower
r6700 replacement power cord
Hi there, In a recent move I seem to have lost the power cord for my r6700 nether nighthawk router. Does anyone know where I can get a replacement power cord? Thanks
michaelkenward
Nov 11, 2022Guru - Experienced User
Thanks
As plemans says, generic adaptors are the answer. (Check that you don't have something suitable lying around.)
I chip in only to suggest that some of the on-line retailers will make compatibility claims for their adapters. Most Netgear kit has the same specs. So that might help to home in on possible candidates.
Try a search for "12 volt adapter netgear". You might be surprised. You need 3.5A or whatever it says on the router's label.
