NetGridlock
Apr 05, 2022Aspirant
R6700 Router Randomly Resets
I have an older nighthawk 6700, 4 years old or so. It started to randomly reset itself. After a few days this resetting/rebooting happened more and more. So, figuring that it might be a power supp...
Apr 05, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Traffic Meter.
- NetGridlockApr 05, 2022Aspirantgot home, booted up laptop (wireed)started with phone (wireless) was connected fine but wired had no internet.Connected!15 seconds later a reboot.Back Alive...The R6700V3 Information:Hardware Version R6700v3Firmware Version V1.0.4.122_10.0.95GUI Language Version V1.0.4.122_2.1.38.1Wireless 2.4 Auto(8)Wireless 5.0 Channel 149 + 153(P) + 157 + 161Guest networks are offClaims this is the latest firmware versionAnother unexpected re-boot!Seems to be doing this more frequently tonight!Cable Modem:TechnicolorModel: TC4310Made in ChinaOld R6700 Router Information:It says it is a R6700V3New firmware is found. Do you want to update the firmware?Current GUI Language Version: 1.0.4.78_2.1.38.1New GUI Language Version: 1.0.4.122_2.1.38.1Current Firmware Version 1.0.4.78New Firmware Version 1.0.4.122_10.0.95I selected not to do the update at this time.It says I was successful Installing it, yah right!OOPSIES! Another random Reboot!Logged back into old router:Hardware Version R6700v3Firmware Version V1.0.4.78_10.0.55GUI Language Version V1.0.4.78_2.1.38.1Wireless 2.4 Auto(3)Wireless 5.0 149 + 153(P) + 157 + 161So, make a guess... The wireless doesn't seem to be an issue even though the channels are different. The issue is that the whole router resets itself.
All the items you wanted disabled were already disabled.
- FURRYe38Apr 06, 2022Guru - Experienced User
Try a factory reset on the router and setup from scratch? Press the reset button for 10 seconds then release.
WIred connect 1 PC to the router and setup from scratch using a web browser.
Might setup the router with it disconnected from the ISP modem to see if the router reboots after it's setup...if not, reconnect to the modem.Power OFF the modem for 1 minute then back on as well.
Swap LAN cables between the modem and router. CAT6 is recommended.
- NetGridlockApr 06, 2022Aspirant
Factory reset has been done, upgrades for the new unit have been done. Both the new and old units continue to reset themselves. They will reset when not connected to anything except power but it is a bit harder to spot it since flashing lights help draw attention to the reset.
I think I will return the new one since it is new. Bottom line, these units do not seem to work and even with different software they don't work. After some research online this resetting issue is not only for this model router. The company has this issue with other models as well. It appears to be a common issue. Why all of a sudden the old unit started doing this I don't know, maybe a software update? I turned off auto updates and it still resets. I have run on different power outlets/circuits and the issue continues.
Frustrating. I have a much older netgear router at a different location and it runs like a champ.
