CCW69's avatar
CCW69
Tutor
Jan 06, 2017
R6700 router setup as access point. Cannot update firmware
I setup my Costco R6700 as an access point. It is running firmware V1.0.0.26_10.0.26. I would like to install the updated firmware that addresses the VU#582384 vulnerability. I downloaded the zip fil...
  • CCW69's avatar
    Jan 06, 2017
    Update.  The previous message/question was for a manual update of the firmware.
    I just tried the built-in update process and that worked. Wo Ho!
    In the past I had no success with the automatic update - usually always getting the "there is no new firmware for your device" (paraphrasing).
    This time it worked. So all is good and as a bonus all of my settings were unaffected.
