CCW69
Jan 06, 2017Tutor
R6700 router setup as access point. Cannot update firmware
I setup my Costco R6700 as an access point. It is running firmware V1.0.0.26_10.0.26. I would like to install the updated firmware that addresses the VU#582384 vulnerability. I downloaded the zip fil...
- Jan 06, 2017
Update. The previous message/question was for a manual update of the firmware.
I just tried the built-in update process and that worked. Wo Ho!
In the past I had no success with the automatic update - usually always getting the "there is no new firmware for your device" (paraphrasing).
This time it worked. So all is good and as a bonus all of my settings were unaffected.
FluffyPup
Jan 06, 2017Aspirant
Sooooooo glad to hear your settings were unaffected. I have been avoiding the update because I didn't want to go through all that.
So let me make sure I understand the difference. (No a networking person.)
You went to the Update firmware on the genie and updated rather than download the zip file. Correct?
CCW69
Jan 06, 2017Tutor
That is correct. My first try was to download the zipped firmware file, unzip it and upload to the router. This method partially started, then the connection was reset and basically failed to update.
I then clicked on the check for updates button on the Advanced->administration->Router update screen. This found the updated firmware, downloaded and installed it (including rebooting the router).
- FluffyPupJan 06, 2017Aspirant
Thanks. That worked much better. Three minutes later, router seems to be it's old quiet self over there in the corner.
If you were to pass these instructions along to some one else, I would suggest you add.
"click on the Backup settings button (just to be safe), then check for updates button on the Advanced->administration->Router update screen. This found the updated firmware, downloaded and installed it (including rebooting the router).
I, however, didn't do that. Saw it while I was sitting there waiting for a reboot. Mine went just fine also. The idea of writting down all the setting is omiunous. Clicking a Backup settings button has a higher probability of being used. I agree, it is always good idea to write down settings any time. But most of us choose to live "dangerously" so to speak.
Thank you again for your help, CCW69. All the best to you in this New Year!
FP
- CCW69Jan 06, 2017Tutor
Sorry, I neglected to mention the backup settings step. I had done that prior to my attempt to manually update the firmware.
