GPLTN's avatar
GPLTN
R6700 Security Vulnerability Firmware Update can't open
Hello. I appreciate any ideas about this. I downloaded the firmware update, but it is a CHK file. When I try to open it goes to Adobe reader, then says Adobe reader cannot open this file. Is there an...
  • netwrks's avatar
    Jan 02, 2017
    Connect to your router - go to update router - browse to the .chk on your desktop - update.. Done..
