heedafaf
Oct 11, 2021Aspirant
R6700 Slow Ethernet Speed
I'm using this router in AP mode and the other router is working fine. If I reboot the router is will get over 200 Mbps but within a few minutes it will drop down to 20-50 Mbps - both test in a wire...
Oct 11, 2021Guru - Experienced User
Have you tried a factory reset?
Did it just start or has it been going on for a while? (if so, how long)
- heedafafOct 16, 2021Aspirant
Thanks for the reply. I did a reset and it didn't help. About 10 minutes later it went from 200+ down to 20-50.
- plemansOct 16, 2021Guru - Experienced User
Does it stay constant in router mode? maybe the primary router you're using has a qos thats slowing it down
Disabled AP mode off it didn't help. The QoS on the other router is off and has never been on. Any other ideas? Very perplexing.
