heedafaf
Oct 11, 2021Aspirant
R6700 Slow Ethernet Speed
I'm using this router in AP mode and the other router is working fine. If I reboot the router is will get over 200 Mbps but within a few minutes it will drop down to 20-50 Mbps - both test in a wire...
Oct 11, 2021Guru - Experienced User
Have you tried a factory reset?
Did it just start or has it been going on for a while? (if so, how long)
