nksharma2
Mar 13, 2023Aspirant
R6700 V2: cannot access web portal after enabling HTTPS.
Yesterday I turned on the HTTPS option on the web portal now I cannot access the router using routerlogin.net.
What I have tried:
1. Tried wifi 2.4 or 5 Hz but not routerlogin.net page is not loading
2. Tried a wired connection but not routerlogin.net page is not loading
What's working:
1. Internet is working on 2.4 and 5 Hz both channels without issue.
2. Mobile app (nighthawk app) is connecting to the router locally successfully, However, the option to disable the HTTPS option is not available there.
I can reset the router and reconfigure that's not an issue but wanted to understand why it's not working when the manual says otherwise.
Thanks - Nishant
Looking for an answer
