Kozey
Dec 29, 2022Follower
R6700 v2
I need to configure my device , so I can connect to the app & update to the new latest firmware somebody please help!!
michaelkenward
Dec 30, 2022Guru - Experienced User
Do you have a problem of some sort? Which app is this? Nighthawk? iOS? Android?
The safest way to update the firmware is manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual on updating the firmware.
Or this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
