gigaboo
Jan 14, 2021Aspirant
R6700 v3 Intermittent connection issues
I just purchased the Netgear Nighthawk AC1750, R6700v3, and while on my laptop, I'll occassionaly see, your internet connection has been restored. All cables are secured, so I'm not sure what the is...
Jan 14, 2021Guru - Experienced User
what modem/gateway do you have?
What firmware is on the router?
You're hardwired into the router when the drops happen?
is wireless dropping? just wired?
Do all devices drop or just one?
- gigabooJan 14, 2021Aspirant
The modem is Arris Surfboard SB6141
Not sure about the firmware, or where to find that. I am hardwired to the router and yes. I have not tried using the laptop on wifi yet, but i don't recall anything else losing connection, like my phone(s)
The firmware is: V1.0.4.106_10.0.80
The current firmware is: V1.0.4.106_10.0.80
- plemansJan 14, 2021Guru - Experienced User
How frequently is it happening?
Usually when wired connections are dropping, we start with the modem. If the drops happen enough (could times a day or so), I'd hardwire into the modem and use it for that period to see if its the modem dropping and not the router.
It usually happens when I first start using the laptop. Antything to do with the type of cable I'm using which is a CAT5E patch cable? Does the amber light for the laptop on the router have anything to do with it?
