barbaric
Oct 28, 2016Tutor
R6700 won't access Seagate 5tb through usb 3.0, only usb 2.0 hub
I have a nighthawk r6700 router that works fine with several hard drives I've tried (up to 4tb). Today I bought a Seagate 5tb Backup Plus, but the router does not recognize it when connected directl...
- Dec 29, 2016
Hi barbaric,
You can check the R7000. They share the same list. If its not on the list, try to use a different USB 3.0 drive just to make sure that the USB 3.0 port is working.
JamesGL
Oct 31, 2016NETGEAR Employee Retired
Hi barbaric,
Let me check on this inquiry. I will get back to you for any update.
JamesGL
Community Team
- barbaricOct 31, 2016Tutor
I exchanged the Seagate Drive for a new identical one, and it has the same behavior. Although both Seagates could be defective, I think it is more likely that something else is going on.
Thanks.
