barbaric
Oct 28, 2016Tutor
R6700 won't access Seagate 5tb through usb 3.0, only usb 2.0 hub
I have a nighthawk r6700 router that works fine with several hard drives I've tried (up to 4tb). Today I bought a Seagate 5tb Backup Plus, but the router does not recognize it when connected directl...
- Dec 29, 2016
Hi barbaric,
You can check the R7000. They share the same list. If its not on the list, try to use a different USB 3.0 drive just to make sure that the USB 3.0 port is working.
Cool1
Nov 15, 2016Aspirant
Having the same problem with seagate 8tb hub
- JamesGLDec 22, 2016NETGEAR Employee Retired
Hi All,
Make sure you are not using a USB hub since the router does not fully support it. It could be the reason why it did not work with 3.0.
JamesGL
Community Team
- barbaricDec 22, 2016Tutor
Hi,
I was using it without a hub, and it would't work. I did try it with as USB 2.0 hub, and that is when it worked. I then tried it with a USB 3.0 hub, and it still didn't work.
Thanks,
Ric
- JamesGLDec 28, 2016NETGEAR Employee Retired
Hi barbaric,
Check the KB article below for the compatible drives.
http://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
