barbaric
Oct 28, 2016Tutor
R6700 won't access Seagate 5tb through usb 3.0, only usb 2.0 hub
I have a nighthawk r6700 router that works fine with several hard drives I've tried (up to 4tb). Today I bought a Seagate 5tb Backup Plus, but the router does not recognize it when connected directl...
- Dec 29, 2016
Hi barbaric,
You can check the R7000. They share the same list. If its not on the list, try to use a different USB 3.0 drive just to make sure that the USB 3.0 port is working.
Cool1
Nov 15, 2016Aspirant
Having the same problem with seagate 8tb hub
JamesGL
Dec 22, 2016NETGEAR Employee Retired
Hi All,
Make sure you are not using a USB hub since the router does not fully support it. It could be the reason why it did not work with 3.0.
JamesGL
Community Team
- barbaricDec 22, 2016Tutor
Hi,
I was using it without a hub, and it would't work. I did try it with as USB 2.0 hub, and that is when it worked. I then tried it with a USB 3.0 hub, and it still didn't work.
Thanks,
Ric
- JamesGLDec 28, 2016NETGEAR Employee Retired
Hi barbaric,
Check the KB article below for the compatible drives.
http://kb.netgear.com/18985/ReadySHARE-USB-Drives-Compatibility-List?cid=wmt_netgear_organic
- barbaricDec 29, 2016Tutor
The main problem with the KB article is that the router I have, R6700, is not listed.
