kcsummer
Nov 10, 2022Aspirant
R6700
I have a new Apple iPad device that I was able to connect thru my router but I had to reset the iPad and start over. But now since the reset it can't connect to wifi. I can see my wifi name but it can...
kcsummer
Nov 11, 2022Aspirant
I think the only hope is to buy a new router and then I will have some support from Netgear for a little while anyway but my income is limited so I'm not sure I can.
I rely on the internet to communicate because of my hearing deficit that makes using the phone very frustrating and unproductive.
At one time I knew how to download updates but that was a long time ago.
kcsummer
I wouldn't be having this problem perhaps if I hadn't gotten the iPad thru assistive technologies which is a program for hearing impaired and other disabilities. Now the iPad that I got from them is no help at all because I can't connect and now I can't download books to read on my Kindle and that's about all there is to do here. I wish I never got the iPad.
- wcalifasNov 11, 2022Prodigy
I would first try to power off the router and power it back on and see if that fixes it. Another thing to do is do a hard reset by pressing the reset pinhole for 30 seconds and see if that fixes things.
