kcsummer
Nov 10, 2022Aspirant
R6700
I have a new Apple iPad device that I was able to connect thru my router but I had to reset the iPad and start over. But now since the reset it can't connect to wifi. I can see my wifi name but it can...
michaelkenward
Nov 13, 2022Guru - Experienced User
kcsummer wrote:
In your response you refer me to manual. What manual? It could be right here in front of my face but I'm not seeing it.
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Nighthawk R6700 | AC1750 Smart WiFi Router | NETGEAR Support
I'm unsure how the modem, router and Apple iMac are to be wired for the internet.
That is kind of important.
The Modem is the thing that is wired to the outside world and the Internet.
The Router is wired to the Modem.
The iMac is wired (or wifi'd) to the router.
Work on it a step at a time.
kcsummer
Nov 13, 2022Aspirant
OMG all those diagrams and arrows and charts send my dyslexic mind into a downward spiral and might as well be written in Greek.
I would like to say that as far as my former Networks "NETGEAR70" and "NETGEAR75" that quit functioning and then disappeared -- that after the hard reset of router and modem at some point they have REAPPEARED. Somewhat. They still don't work but they are listed. Do you think that all the elements are still there as when they were originally set up?
The yellow cable in the diagram doesn't fit into any opening where the disagram shows it to be on the Netgear Router.
There's a blue cable coming from the router but its not plugged in anywhere, don't know where its supposed to go if anywhere.
I am totally clueless. A little bit of knowledge can be a dangerous thing and I definitely fall into the category of a VERY LITTLE BIT of knowledge.
In my defense, I would say it wasn't always so. But with retirement I quit following all that technology stuff and what's left is an empty shell of my former self in the marketplace.
A mind is a terrible thing to waste. Somebody else said that, not me, I'm just agreeing. Except in certain environments there's not much choice and that's where I am. I moved from a large metro area to a dead and/or dying town of 500 people because in the midst of the "pandemic" it was the only place I could find and afford. BAD MISTAKE because now I think I'm afflicted with "Wasting Away" Disease. Which matters not to my Netgear Router. Just an explanation or defense after having FALLEN from grace in the world of business.
Here, alone, as I am in this dried up excuse for a town (where you can buy a gallon of gas, and a soft drink in your choice of paper or plastic cup and that's about it. I feel hopelessly unable so I'm sure you have other important things to do. Thank you for your help.
- kcsummerNov 13, 2022Aspirant
Apple Store says the Net Genie is designed for the iPad and mine doesn't work because it can't connect to the internet. Must be an example of CATCH 22. And anyway about the Net Genie - here's what Apple has to say:
The item you’ve requested is not currently available in the U.S. store.
I hate Apple.
If I take the middle cable out of the back of the modem and put it into the back of the Apple Desktop then the desktop still works.
If I take it out of the Desktop and put it into the Router then NOTHING WORKS.
So I guess I should be grateful the desktop still works and leave well enough alone because if that goes then I will be isolated with no means of communication other than smoke signals.
