TPreston3790
Aug 13, 2021Aspirant
R6700v2 - 1-2 second intermittent disconnects
Hello! So I think my router (and possibly modem) might be on their last legs, but I wanted to see if y'all have any alternative solutions other than just buying a new modem and router. They are about...
TPreston3790
Hey! Yes the R6700v2.
Connected to an Arris Surfboard SB6190
Everything drops. I have an xbox (hard wired in), personal pc, and work pc that are on wifi and they have all dropped simultaniously. Seems to be a total connection thing not just one device.
I have V1.2.0.76_1.0.1 which shows to be the latest one when i check for updates.
michaelkenward
Aug 14, 2021Guru - Experienced User
Standard modem only device with no built-in router to get in the way.
Not the most reliable guide if you mean getting the thing to check the firmware.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
- TPreston3790Aug 15, 2021Aspirant
Thank you for the reply! I went to the support page and I do indeed have the latest firmware update. Seems as everything is as up to date as possible. Any ideas?
- plemansAug 15, 2021Guru - Experienced User
do you have a screen snip of the modems logs and cable connections page?
When everything is dropping, its always good to rule out the modem first
- TPreston3790Aug 16, 2021Aspirant
Sun Aug 01 17:05:47 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Sat Aug 07 22:20:39 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Mon Aug 09 13:51:31 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Tue Aug 10 13:21:58 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Tue Aug 10 14:24:32 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Wed Aug 11 12:20:44 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Wed Aug 11 13:41:42 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Wed Aug 11 15:08:32 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Thu Aug 12 11:53:13 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Thu Aug 12 18:09:01 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Thu Aug 12 18:21:16 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Thu Jan 01 00:02:29 1970 3 DHCP failed - DHCP Solicit sent, No DHCP Advertise received;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Fri Aug 13 14:35:22 2021 6 TLV-11 - unrecognized OID;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0; Fri Aug 13 14:47:36 2021 3 No Ranging Response received - T3 time-out;CM-MAC=5c:e3:0e:3a:f3:0b;CMTS-MAC=00:38:df:08:86:b4;CM-QOS=1.1;CM-VER=3.0;
