decker12
Dec 06, 2018Star
R6700v2 - Where is Downstream QOS?
I'm fiddling around with QOS settings on my R6700v2, but I can't find any option for Downstream bandwidth settings. I can only see Uplink bandwidth settings, which isn't useful for what I can imagine...
- Dec 06, 2018
Neither the R6700v2 Data Sheet nor the User Manual does list the second half of the feature you are behind, there is only a global Uplink Bandwidth Control, no Downlink Bandwidth Control.
schumaku
Dec 06, 2018Guru - Experienced User
Netgear does designate this as...
"Manage Uplink Bandwidth
Control Uplink bandwidth control lets you check the maximum uplink bandwidth that your Internet connection can support and specify the maximum uplink bandwidth."
...it's independant of the QoS rules which can be set in place.
