decker12
Dec 06, 2018Star
R6700v2 - Where is Downstream QOS?
I'm fiddling around with QOS settings on my R6700v2, but I can't find any option for Downstream bandwidth settings. I can only see Uplink bandwidth settings, which isn't useful for what I can imagine...
- Dec 06, 2018
Neither the R6700v2 Data Sheet nor the User Manual does list the second half of the feature you are behind, there is only a global Uplink Bandwidth Control, no Downlink Bandwidth Control.
schumaku
Dec 06, 2018Guru - Experienced User
Netgear does designate this as...
"Manage Uplink Bandwidth
Control Uplink bandwidth control lets you check the maximum uplink bandwidth that your Internet connection can support and specify the maximum uplink bandwidth."
...it's independant of the QoS rules which can be set in place.
decker12
Dec 06, 2018Star
I don't think that quite answers my question. Let me word it this way.
I have a 300mb/s down, and 15mb/s up connection.
Hypothetically, I want to permanently limit my entire network to only use maximum of 100mb/s down and 5mb/s.
On other routers, I have both a downstream and upstream setting, so I'd set it to 100mb/s down and 5mb/s.
On my R6700v2, I only have the option to set an upstream setting. If I set the upstream on the R6700v2 to 5mb/s, speedtests show me with a 300mb/s download speed and a 5mb/s upload speed.
How do adjust both the downstream and upstream on my R6700v2?
- schumakuDec 06, 2018Guru - Experienced User
- decker12Dec 06, 2018Star
Right you are. Thanks for the reply.
Baffling omission from Netgear. I can't imagine why they would bother including a QOS service that only works on the uplink side. If you wanted to prioritize, say, an incoming video conference or VOIP call over whatever someone else who is streaming on Netflix, you can't. I don't know how the per service or device QOS rules can function in a downlink situation without knowing what the available bandwidth is.
- myerswDec 06, 2018Master
Download is going to you and you may not have any control over accepting other then no resend. Upstream the router does have some control over. Therefore QoS only looks at upstream which in effect controls the download as TCP IP is a send and listen for a good response (ack) before sending more.
