kschmitt23
Jun 08, 2018Aspirant
r6700v2 -Cannot Login into my router
So, I've had this router for a few months and it's worked great. We just moved into a new place and had to have Mediacom for our internet, they came in and set up their modem and everything on Tuesd...
- Jun 13, 2018
Hi kschmitt23,
May I please know the brand and model of the modem. Per your last update, Internet LED is amber. Do you have Internet connection straight from the modem?
Please temporarily disconnect the router from the modem, leave the computer connected to the router WiFi network and try accessing the network.
Blanca
Community Team
kschmitt23
First of all, I am using the IP address that I am getting from my system preferences ( 192.168.0.233). When I type that into my address bar I get the error message:
This site can’t be reached
192.168.0.233 refused to connect.
The name address doesn't work either.
If you need more details:
I can do anything online using google chrome on my macbook air. On my phone none of my apps work saying I need to check my internet connection, and retry later - or they simply load until they time out. Our PS4 will simply not connect to the internet. I'm not sure how much more detailed about this I can be, I have no idea why chrome works on my computer.
I thought I had it figured out, was out of the house for about 2 hours came home and the internet LED light was solid amber again. The only way to get the internet to work is to reset the modem, naturally I don't want to do this several times a day and I STILL am not connected to the wifi through my router.
antinode
Jun 09, 2018Guru
Which "the IP address that I am getting from my system preferences"
is that? Around here, for a wireless connection, System Preferences >
Network shows the computer's _own_ IP address ("IP address"). If you go
from there to Advanced... > TCP/IP, then you should see the computer's
own IP address ("IP address:"), a "Subnet Mask:" (typically
"255.255.255.0"), and a "Router:" address. Nearby, Advanced... > DNS
should show one or more "DNS Server:" addresses. What are all those
data on your MacBook?
> This site can't be reached
If you're pointing your web browser at your computer's own IP address
(and you're not running a web server on your computer), then that would
be an expected result. Note that this error differs from the "not
connected" error reported originally.
If you point your web browser at the "Router:" address, then you
should reach your router. (If your computer's IP address is
"192.168.0.233", then my guess for the router's IP address would be
"192.168.0.1".)
Ok. That suggests that the router is connected to the Internet.
Which wireless SSID did you specify on the MacBook? Can you see that
SSID on your other devices? Are you trying to connect to it on them?
> [...] On my phone none of my apps work saying I need to check my
> time out. [...]
Did you get these devices to connect wirelessly to the router?
> [...] I've done a factory reset, [...]
That should reset any wireless credentials (SSID, passphrase) back to
their default values (as shown on the product label). If your other
devices are still configured to use some customized wireless credentials
(from before the settings reset), then you'd need to re-configure the
router's wireless stuff, or else re-configure the wireless parameters of
the devices.
> [...] I'm not sure how much more detailed about this I can be, [...]
I do. Plenty more. If your MacBook can talk to the Internet, then
it should be able to talk to your router. (See above.)
> [...] Our PS4 will simply not connect to the internet.
When you do _what_? Clearly, you need to tell the PS4 about your
wireless network. What information are you giving it? What information
can you get from the router about its wireless configuration?
> [...] I have no idea why chrome works on my computer.
I don't know why it wouldn't, but I can't see what you're doing.
> [...] came home and the internet LED light was solid amber again.
You'd need to talk to the router to see what's happening. I'd work
on that.
Who's your ISP? What feeds the router? What's connected to its
WAN/Internet port? Does that device have LED indicators which indicate
anything?
- Blanca_OJun 17, 2018NETGEAR Employee Retired
Hi kschmitt23,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
