silverhand's avatar
silverhand
R6700v2 2.4ghz not working, but 5ghz is fine
I have seen many people posting about the same problem and then we are told to do updating the firmware and factory reset. I have done all those are suggested. And my 2.4ghz wifi is still not working...
  • Blanca_O's avatar
    Blanca_O
    Jun 04, 2018
    Hi silverhand,
    Was this working before?
    I suggest to change 2.4GHz wireless channel.
    How do I change the wireless channel on my NETGEAR router?
    https://kb.netgear.com/23783
    For isolation, please enable 2.4GHz Guest network and check if you can detect the network.
    How do I set up a guest network on my Nighthawk router?
    https://kb.netgear.com/24097/
    Blanca
    Community Team
