bmkantor
Nov 12, 2023Tutor
R6700v2 Cannot Turn On Access Control
I'm running outer Firmware Version V1.2.0.92_1.0.1 (latest) on my R6700v2 and I cannot turn on access control. I select "Security" then "Access Control" and check the box to "Turn on Access Control" ...
- Nov 12, 2023
I would try from scratch. Whenever I've had an issue with firmware, its usually in the backup as well.
I'd keep with the latest and see if it works. If it doesn't, you can always downgrade and see if it was a firmware issue or just a setting not carrying over correctly
bmkantor
Nov 12, 2023Tutor
Thanks. I'll try a factory reset next. Do you think it would be ok to restore settings from a backup or should I reconfigure it from scratch. Should I also continue to use the latest firmware or downgrade?
Nov 12, 2023Guru - Experienced User
