ColonelBologna
Nov 11, 2017Aspirant
R6700v2 Corrupt firmware? Plz help.
I just got my R6700v2 this morning. During setup, it froze/crashed. Waited a few minutes to be sure, turned the router off/on and could no longer connect to it. (wired connection) Figured...crap. ...
- Nov 11, 2017
Problem solved!
I ended up using windows TFTP service to place the new firmware and that was succesfull. The router did not auto reboot, but after i places the file, and restarted the router, it came back to life!
ColonelBologna
Problem solved!
