Mister36
Nov 29, 2017Follower
R6700v2 Dropping Wireless Connection on one PC
I just got my Nighthawk AC1750 yesterday, setup went fine, created 2.4 and 5G wireless, added phones and laptops, and speeds greatly increased from my old Netgear. However, I have the problem of ...
- Dec 06, 2017
Hi Mister36,
Can you connect the laptop to 5Ghz?
Can you try changing the channel for 2.4Ghz?
If still the same after changing channel, Try to reset the router.
Try older firmware as well if still the same after the reset.
JamesGL
Dec 06, 2017NETGEAR Employee Retired
Hi Mister36,
- JamesGLDec 12, 2017NETGEAR Employee Retired
Hi Mister36,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
