Marlene8
Oct 12, 2021Aspirant
R6700v2 Ethernet ports don’t output internet
R6700v2 nighthawk AC1750 When I plug an Ethernet cord into any of the ports 1-4 and than connect the other end to example computer or another device needing Internet it doesn’t have internet connecti...
Marlene8
Should I change the router to AP mode…?
- michaelkenwardOct 13, 2021Guru - Experienced User
Marlene8 wrote:
Should I change the router to AP mode…?Only if you have a modem/router between the R6700v2 and the Internet.
Again, you don't provide enough information. What is your modem,if there is one?
