Marlene8
Oct 12, 2021Aspirant
R6700v2 Ethernet ports don’t output internet
R6700v2 nighthawk AC1750 When I plug an Ethernet cord into any of the ports 1-4 and than connect the other end to example computer or another device needing Internet it doesn’t have internet connecti...
Oct 13, 2021Guru - Experienced User
michaelkenward Is correct.
We need more info to help you.
1. what modem/gateway are you connecting to?
2. what firmware is on the router?
3. You're able to connect to the router but not to your gateway (hint again on what gateway you have). Are you able to ping the gateway using its address?
4. what does your internet statistics page show?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
