FlyingTiger
Apr 30, 2020Tutor
R6700V2 failed to connect to internet
I have R6700V2 as my main router for two years. It worked fine until a few days ago. It suddently stopped working a couple of days ago. I did some triages and isolations and confirmed it is R6700 r...
- Apr 30, 2020
thank you, Pleaman. I will download the FW and give it a try.
Apr 30, 2020Guru - Experienced User
Did you try re-installing or downgrading the firmware?
A factory reset only removes the settings. If something was corrupted in the firmware, a reinstall of the firmware can sometimes fix this.
Or try downgrading the firmware. maybe it updated to a newer version and has issues on it.
- FlyingTigerApr 30, 2020Tutor
- FlyingTigerMay 02, 2020TutorReinstalled latest FW did recover the router. Thank you for the tips.
- plemansMay 03, 2020Guru - Experienced User
glad to hear you got it working!
