Alex_W
Sep 28, 2021Initiate
R6700v2 Firmware Update Breaks Readyshare Write Access
I recently updated the firmware on my R6700v2 to 1.2.0.88, and after that I could not get write access from my computer to the drive on the routers readyshare USB port. The settings in the router ar...
Alex_W
I didn't try a reset to factory settings, although I did reboot the router when I first discovered that it wasn't working.
Sep 28, 2021Guru - Experienced User
Next time you update and have issues, try the factory reset. If that doesn't work, then try the downgrade.
But for how I'd leave it. The latest round of updates hasn't been getting good reviews.
