lolhelloeddie's avatar
Jul 07, 2019
R6700v2 firmware update brick my router
So I logged into the admin page where you manage the wireless router. I seen that I had an alert to update my router firmware. So I accepted the update let everything run. When I go back and check up on it the power light is like a orange color and it isn't broadcasting the wifi signal either 2.4g or 5g. I tried to do reset and it won't do it I hold it down for couple of seconds and it don't reboot. Can someone please help me.
  • > [...] the power light is like a orange color [...]
       Solid?  Flashing?
    > [...] it isn't broadcasting the wifi signal [...]
       Wired connection?
       You may be a candidate for the TFTP recovery scheme.  See, for
    example:
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
    But you will need a computer with a wired (Ethernet) connection to make
    that work.
1 Reply
       Solid?  Flashing?
       Wired connection?
    example:
    that work.
