ColoradoYeti
Mar 16, 2021Aspirant
R6700v2 firmware update unsuccessful
I tried to update my firmware (from 1.2.0.74 to 1.2.0.76) this afternoon after noticing spotty internet on my wifi devices. I updated the router via the netgear app, however, the app never came back ...
antinode
Mar 16, 2021Guru
> [...] since been nonfunctional.
Which kind of "nonfunctional"? LED indicators?
> I have tried the command prompt TFTP method [...]
The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error. By itself,
saying that you "tried" it doesn't say much.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations. Especially when using a command-line
program, copy+paste is your friend.
> I have not been able to ping the router using the default 192.168.1.1
> or 192.168.0.1 ip addresses.
For an Rxxxx model, the default LAN IP address would be
"192.168.1.1".
"not able" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. See "As usual,
[...]", above.
> I have tried the TFTP schemes as outlined in the following: [...]
I'd concentrate on: https://kb.netgear.com/000059634
ColoradoYeti
Power LED indicator is either a solid stable orange, or blinking white depending on if a 30-30 reset was done recently.
connected laptop is the only device connected. modem has also been disconnected. laptop has
- IP address => 192.168.1.10
- Subnet mask => 255.255.255.0
- Default Gateway => 192.168.1.1
router turned off for 10 seconds. powering on with reset button held down for 10 flashing power led cycles, and then released.
command prompt executed.
Command prompt TFTP resulted in the following.
C:\Users\XXXXX\Desktop>tftp -i 192.168.1.1 put R6700v2-V1.2.0.76_1.0.1.img
tftp: can't read from local file 'R6700v2-V1.2.0.76_1.0.1.img'
copied and pasted the file name from the desktop file icon, and added the .img as per item description.
Sending a ping to the default IP address resulted in the following.
Pinging 192.168.1.1 with 32 bytes of data
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
- ColoradoYetiMar 16, 2021Aspirant
I was using a work laptop that has some OneDrive functions that were not allowing me to read from the actual desktop folder, hence the can't read from local file.
I have switch to my personal computer, and now the error is simply "connect request failed"
ping to the default 192.168.1.1 still yields no returned data packets.
I know this is ultimately going to be chalked up as user error, and I appreciate your help in troubleshooting the user.
- antinodeMar 16, 2021Guru
> "connect request failed"That makes more sense.
If you can't find a time window where that "ping" command works, then
I wouldn't expect the TFTP command to work, either, even if the TFTP
program could find the file.If you can't find some power-on/reset preocedure which leaves the
device more responsive, then TFTP might not do the job.The next level tools are the "nnmrpflash" program, or using a
serial-port interface.
