mrcatj
Nov 12, 2017Aspirant
R6700v2 Freezing when USB Drive is plugged in
Hoping that someone can help here. I have a Nighthawk R6700v2 that has been working flawlessly on the previous Firmware. When i recently updated to the latest (V1.2.0.4_1.0.2), everything was wor...
- Nov 19, 2017
Hi James,
I have received the replacement unit, set it up and downloaded the new firmware. I plugged my HDD in and setup readyshare with success - no freezing!
Apparently it was a defect, just with an odd timing. Customer service was good. Thanks again for your responses.
JamesGL
Nov 15, 2017NETGEAR Employee Retired
Hi mrcatj,
If you revert to previous firmware, will you have the same problem?
mrcatj
Nov 16, 2017Aspirant
Hi James
Thanks for your help here. I did roll-back the firmware to the previous one and had the same issue. I tried different cables, different HDD and no luck!
I just got off the phone earlier with NETGEAR Tech Support who took me through all of the things that I tried again, and they determined that it must be a hardware issue and will replace it under warranty.
Thanks again for your reply. Strange that it coincided with a firmware update then subsequent power-cycle?!?!
- JamesGLNov 16, 2017NETGEAR Employee Retired
Hi mrcatj,
Update us once you receive the replacement unit.
- mrcatjNov 19, 2017Aspirant
Hi James,
- JamesGLNov 19, 2017NETGEAR Employee Retired
Hi mrcatj,
I am glad to know it works now. It was a pleasure assisting you.
