swiftdr's avatar
swiftdr
Initiate
Dec 14, 2020
R6700V2 keeps rebooting after firmware update
I recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and it keeps rebooting. It has rebooted at least 3 times today. Can I rollback the firmware update? If so, where can I download the old...
  • plemans's avatar
    Dec 14, 2020
    You can rollback the firmware.
    Before doing that, I'd actually reinstall the firmware over a hardwired connection, then factory reset, and do a manual reinstall (not from a backup configuration).
    to get the firmware. go to the support site and click on downloads.
    You can get the current under the downloads and the older version you'd click on "+view previous versions"
    https://www.netgear.com/support/product/R6700V2.aspx
