swiftdr
Dec 14, 2020Initiate
R6700V2 keeps rebooting after firmware update
I recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and it keeps rebooting. It has rebooted at least 3 times today. Can I rollback the firmware update? If so, where can I download the old...
- Dec 14, 2020
You can rollback the firmware.
Before doing that, I'd actually reinstall the firmware over a hardwired connection, then factory reset, and do a manual reinstall (not from a backup configuration).
to get the firmware. go to the support site and click on downloads.
You can get the current under the downloads and the older version you'd click on "+view previous versions"
Brad1974
Dec 17, 2020Initiate
Same thing is happening to me. It appears to be rebooting every 2.5 hours...
