swiftdr
Dec 14, 2020Initiate
R6700V2 keeps rebooting after firmware update
I recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and it keeps rebooting. It has rebooted at least 3 times today. Can I rollback the firmware update? If so, where can I download the old...
- Dec 14, 2020
You can rollback the firmware.
Before doing that, I'd actually reinstall the firmware over a hardwired connection, then factory reset, and do a manual reinstall (not from a backup configuration).
to get the firmware. go to the support site and click on downloads.
You can get the current under the downloads and the older version you'd click on "+view previous versions"
swiftdr
Dec 17, 2020Initiate
I rolled back the firmware to the next most recent update and the problem stopped. I guess I'll wait for the next update and try updating again.
- jw2021Jan 01, 2021Aspirant
I, roo, recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and since then the router has been rebooting every few hours or so. I have updated the firmware from an attached system and performed a hard reset on the router, but still the same issues others have seen. Because of the vulnerabilities in the previous version, I hate to downgrade the firmware back to what i was running previously. However, if trying to keep a reliable internet connection going, I may need to downgrade. Is there a timeframe when Netgear Support will address this issue? Thanks!
- Brad1974Jan 02, 2021InitiateI downgraded mine to the previous FW and it has not rebooted since I did that...
