dinosaur_sr
May 09, 2018Aspirant
R6700v2 LEDs not functioning correctly, firmware version V1.2.0.16
Need some help with the LEDs on my R6700v2 not lighting up correctly. Confirm I'm on the latest firmware and routerlogin.net LED settings are correct.
The problem started when my WiFi and wire...
- May 10, 2018
It looks like it is the power LED that is not working.
That is usually a sign of broken firmware.
There is a manual for the R6700v2 somewhere at the end of this link:
>>>R6700V2 | Product | Support | NETGEAR <<<<
See page 216.
That the thing still works is odd. Might be worth reflashing the firmware, just in case it didn't stick.
I would also check that the power adapter is OK. If you have a spare with the same specs, try that.
michaelkenward
May 10, 2018Guru - Experienced User
See page 216.
- dinosaur_srMay 14, 2018Aspirant
Sorry for the late reply and big thanks for response! Powering down and unplugging the power adapter from the router did the trick.
Thanks again for your help!
