dafish1900
Dec 28, 2020Aspirant
R6700v2 Lost remote management access
I've used Remote Management for a few years without a problem. I have two Netgear router in two different homes and I sometimes need the remote management features. As I said has worked fine for some...
JustRay
Jan 04, 2021Aspirant
I am having the same exact problem. Same model router as you and just did the latest firmware update. Remote management broken!
- dafish1900Jan 05, 2021Aspirant
No solutions yet. But I did find the older version if I want to downgrade back a version. Problem with that is I am remote from the router so a downgrade to the older version will, likely, reset all my configurations including enabling remote management and my VPN connection leaving me with no way to get back on the device remotely (right now, even with remote management lost, I still have a backdoor to the management of the router through the VPN connection - but that will likely be lost if the router resets all parameters after I downgrade NETGEAR - IS THAT THE CASE? I COULD USE SOME ADVICE HERE!!!)
