twaw001
Jan 03, 2022Tutor
R6700v2 No option shows for Remote Management at all, Nighthawk app won't reboot
I'm trying to establish a way to remotely reboot the router. I'm currently at the router location. I recently had an internet outage but power was on, and I couldn't reboot it remotely, so i'm tryi...
Jan 03, 2022Guru - Experienced User
I believe NG has removed web browser based remote access in recent FW versions and is only allowing remote access using the Nighthawk app to remote connect when Anywhere Access is enabled on the mobile app.
