PDAdamczyk's avatar
PDAdamczyk
Initiate
Sep 05, 2024
R6700v2 not showing Wired Devices
Hi all, After a long trouble free run, my R6700v2 is not recognizing / showing wired devices. One of two things happen when I load the Attached Devices screen - or check the Nighthawk app - A sub...
  • PDAdamczyk's avatar
    Sep 05, 2024
    The mystery deepens.
    The problem fixed itself!‽‽‽
    All I did was turn on a few of the devices that go through the switch:
    • laptop w/wi-fi turned off
    • AVR with an ethernet connection
    • Chromecast w/wi-fi turned off and ethernet adapter plugged-in
    ... and all of the wired devices, including a PoE WAP and other devices that were not power-cycled all came back online and now appear consistently on the Attached Devices screen.
    Glad it's fixed; annoyed that I don't know what caused it or what precisely resolved the issue.
