Retired_Member's avatar
Retired_Member
Jan 27, 2018
R6700v2 Plex port 32400 is closed suddenly
My Plex remote access was working without any extra setting. However, it's suddenly not working. I checked my ip and 32400 was closed. I went to the router and tried port forward to TCP 32400, but i...
  • Retired_Member's avatar
    Retired_Member
    Jan 29, 2018
    After I reboot the router it works. Then a day later it stops again.
    UPNP does not always show the correct information(Didn't show 32400 in the list). Even you set Plex to manual (UPNP should be off) but it seems router still picks it up. I turn off UPNP from the router then I am able to set 32400 for port forwarding. After all settings done, then turn the UPNP back on.
