d00gy's avatar
d00gy
R6700v2 wireless speeds drop quickly after reboot.
Hello, I'm having issues with my newish Nighthawk router.  Honestly I don't think it's been quite right since purchased three months ago.  WiFi speeds would drop over the course of a week but now wi...
  • d00gy's avatar
    d00gy
    May 22, 2018
    Hanging the router has definitely helped, but not near the ceiling.  Hard to imagine the router's position had so much to do with it but hanging the router only a few feet down from the ceiling resulted in a much poorer signal than four feet from the floor.  Also rotating the router 180 degrees (so the antenna face out) resulted in a poor signal.
    After installing a ASUS PCIe dual band AC1200 network card in the wireless desktop I am now getting roughly the same speed of that on the Ethernet attached PC.  All of the wireless devices get a good signal now & the wireless speeds remain constant throughout the day.
    Very happy with this router at this point.
    p.s. I did turn off the traffic meter, the logging function too & some of the other tricks suggested here.  However I had tried all that before moving the router to different positions.  Maybe not the logs?
