timnguyen1002
Mar 02, 2021Aspirant
[R6700v3 — Nighthawk AC1750] maximum device connection
Dear all,
I am using the R6700v3 — Nighthawk AC1750 router and I have 2 questions for it.
1. How many connections max that the devices can connect to this router?
2. If a device is disconnected to the router, how long the router will release the connection for this device to be able to have room for the new devices?
I appreciate the help.
Thanks,
Tim
are you wondering about wireless or wired?
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
- timnguyen1002Aspirant
Hello,
I am wondering about wireless.
> router?For wireless devices, the claim is 32/radio.
That says "per band", but some newer models have more than one radio per
band.> 2. If a device is disconnected to the router, how long the router will
> new devices?Exactly what kind of trouble are you expecting?
I would not expect the wireless-device limit to be related to the
DHCP lease time. I'd expect the actual connection to be forgotten
pretty quickly after one side disappears, but I know nothing.
> I am using the R6700v3 [...]I'd run the experiment. I'd trust actual behavior over any wisdom
you might find here.
