timnguyen1002
Mar 03, 2021Aspirant
[R6700v3 — Nighthawk AC1750] maximum device connection
Dear all, I am using the R6700v3 — Nighthawk AC1750 router and I have 2 questions for it. 1. How many connections max that the devices can connect to this router? 2. If a device is disconnected...
timnguyen1002
Mar 06, 2021Aspirant
The trouble is I am using this router on the factory and many of phones 100+ are being connected to this router. So I wonder the max connection and lease time.
antinode
Mar 06, 2021Guru
> phones 100+ are being connected to this router. [...]
Ah. Sometimes, when looking for a solution, it's helpful to describe
the actual problem.
So far as I know, no Netgear consumer-grade router provides a
supported way for the user to adjust the parameters of its DHCP server.
I don't know if it's the same on all models, but on my D7000[v1], the
DHCP lease time is 86400 seconds (24 hours).
A simple, if inconvenient, work-around would be to restart the router
periodically, or when it gets into trouble.
Another possibility would be to use an independent DHCP server which
does allow the user to adjust its parameters. Perhaps something like a
Raspberry Pi?
