kyk
Sep 05, 2021Tutor
R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router DNS problem with Spectrum
DNS Problem I have an R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router I have an ongoing internet problem. This is randomly occurring. It’s not site specific but happens on some sig...
Sep 05, 2021Guru - Experienced User
How longs it been going on?
The last firmware pushed out seemed to cause a lot of dns issues.
Most fixed it by downgrading a version and are now waiting on netgear to update.
have you tried this?
kyk
Sep 05, 2021Tutor
Thank you. I'll try downgrading my router.
Another observation...
I don't seem to have the problem when connect through a VPN.
- Jambo11230Nov 09, 2021Aspirant
Did downgrading your firmware resolve your issue? I've just moved to Spectrum, and I am using the R8000P. I am receiving intermittent DNS_PROBE_FINISHED_NXDOMAIN errors, with very similar behavior to that which you describe. Roku works fine, Phones work fine, Windows PCs all exhibit errors.
- kykNov 09, 2021Tutor
I started using a vpn. That took care of the problem for me.
I'm curious though, did you have the problem with your last provider?
I'm thinking it's a spectrum problem.
Maybe Windows 11 will help.
- Jambo11230Mar 03, 2022AspirantDowngrading helped to a point, but I frequently need to reload web pages on chrome. The router worked swimmingly in our old home, using FIOS. I've had Spectrum techs out to the new place on several occasions. They see no problem with their connection and modem (which they replaced with an updated model once). They blame the Netgear Router. Its all pretty frustrating.
