kyk
Sep 05, 2021Tutor
R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router DNS problem with Spectrum
DNS Problem I have an R6700v3 — Nighthawk AC1750 Smart WiFi Dual Band Gigabit Router I have an ongoing internet problem. This is randomly occurring. It’s not site specific but happens on some sig...
Kitsap
Mar 03, 2022Master
Yes, the ntp time issue could impact your DNS response. The Netgear time server always seemed inconsistent in its response to my location. Sometimes it responded quickly and sometimes not.
Do a search for ntp servers. Several options will come up if you are in the US. One is pool.ntp.org. I use this one in Washington state and it works fine with OpenDNS.
Here is a link: https://timetoolsltd.com/information/public-ntp-server/
From the government, try time.nist.gov.
kyk
Mar 04, 2022Tutor
Problem solved. Moved to a new house. Still have Spectrum but everything works here. Looks to me like there was a connection issue at the old house.
Note, I was moving anyway, I didn't buy a new house to fix the issue.
- FURRYe38Mar 04, 2022Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-Systemhttps://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
