seifrjd
Feb 08, 2023Aspirant
R6700v3 -- older firmware
I have an R6700v3 router, and I am experiencing SLOW download speeds. I read multiple threads that address slow downloads through the ISP after applying firmware version V1.0.4.128_10.0.104. The s...
- Feb 08, 2023
I found my own answer. Sorry for taking your time and space.
For anyone else with the same questions, here's the link... prior versions are near the bottom right of the page.
seifrjd
Feb 08, 2023Guru - Experienced User
I also saw posts where some users contacted NG support and was given a non published beta that seemed to solve problems as well. Might make contact with NG support and ask about this as well.
Good Luck.
- seifrjdFeb 08, 2023Aspirant
Thanks for the suggestion. I'm beyond my support period, so not sure if they'll talk to me. PS - also sending you a PM re: the beta firmware for RAX120v2.
