tanzo
Aug 30, 2023Follower
r6700v3 - any way to remotely manage advanced settings?
Remote management doesn't seem to be an option anymore without using the Nighthawk app. But I can't find a way to change advanced settings like port-forwarding in the app. Is there no way to manage t...
Aug 30, 2023Guru - Experienced User
Have a running PC at the same location at the router and install a remote access app like Team Viewer or Remote Desktop and then access the routers web page thru the remote PC.
tanzo wrote:
Remote management doesn't seem to be an option anymore without using the Nighthawk app. But I can't find a way to change advanced settings like port-forwarding in the app. Is there no way to manage these things remotely now?
