Dentyuns
Jul 18, 2021Aspirant
R6700v3 - Can't Log into Router
I'm at my wits end! I can't log into my router. I took several hours on many days to do the following: - I have the NightHawk app and used to go into it easily. Now it rarely finds connection...
Jul 19, 2021Guru - Experienced User
what actual modem/gateway do you have it connected to?
Is the router working fine otherwise?
- DentyunsJul 20, 2021AspirantIt’s connected to CM600.
The router is generally working fine, in the broadest statement. At times throughout the hours, it could very slow or no internet.
But what I want to do is to access the router to enable the internet for my printer. But cannot in anyway access the router.- plemansJul 20, 2021Guru - Experienced User
Did you try a simple factory reset of the router? And then do a new install on it?
- antinodeJul 21, 2021Guru
> - I have the NightHawk app [...]
I'd use a web browser. Less unreliable Netgear software involvement.
> [...] go to routerlogin.net or routerlogin.com. It just redirects me
> to a page that says I'm not connected to the router [...]https://community.netgear.com/t5/x/x/m-p/1976674
> - Use my default IP address. Also gets stuck and never loads.
What is that "my default IP address"? Elaborate on "gets stuck"?
> - Reset my router. [...]
How, exactly? Did you press the button for at least two seconds?
Did the LEDs do interesting things?Try connecting a computer (using Ethernet), but no other devices
(modem, other computers/devices), and see what happens.
If the router firmware has become corrupt to the point where its
management web site is not responding properly, then you might want to
explore using the TFTP recovery scheme to cram a firmware image down its
throat. See, for example:
